IPhone or Android?
07-07-2017 10:57 AM - edited 01-05-2022 02:23 AM
07-07-2017 07:56 PM
@srlawrenHaha, yes, you're correct. A BlackBerry Mobile device running BlackBerry's Android release.
07-07-2017 07:43 PM
Wow, @jeffster1970, it sounds like you need to hang on to your phones better! LOL. Sorry just joking around. I'm glad (and slightly surprised) that the iPhones are so durable for you. You could also consider a case, especially something rugged [and unfortunately bulky] like an Otter Box if you are really hard on your devices, or even a simple TPU case that has a slight lip around the screen will help a LOT. Or if you ever do want to come back to Android, you could try something like the "Active" variants of the Samsung flagships, that are mant to be more rugged.
07-07-2017 06:38 PM
I'll be the exception here and say Apple. I was on Apple originally, used the phone until it was pretty much undated. That phone was dropped, thrown, everything, never stopped working. Nor any cracks on screen. (I had come to Apple from BlackBerry and feature/dumb phones before that) My first Android was a Nexus 4, screen crack, as did the back, got it fixed, screen cracked again, so I got a Samsung S3. Bonus was expandable memory over the Nexus, but too much bloatwear. Screen cracked, had it replaced, LCD cracked (not screen) so I got an Moto X Play screen shattered on bottom corner (drop of 2 feet) so I got a Huawei (can't recall model number) and it dropped into the water, the insurance (through Freedom) couldn't get me a replacement so they sent me a cheque for $350. Repaired Nexus 4 one last time, and screen cracked randomly about 2 months later. So I booted up on S3 (the ex's) which also had a cracked screen, but otherwise functional. Ended up buying an iPhone SE.
I do get the frustration of the way it downloads music and video's (like, you can't download off of the web and expect iTunes to open and store it), but the phone is solidly built. Already dropped about 4 times, face first a couple times, no scratches, not cracks. Just like the first iPhone I had, it's simply more resilient. Plus with AppleCare, they actually can replace the phone if you toast it. ( I recall $29 for cracked screen, $99 if the phone is damaged beyond repair ).
I still slightly prefer Android, if it is stock for sure, and I loved the Huawei phone that I had (my favourite by far), however, I need a phone that can be backed up more seamlessly, replaced easily, and Apple simply does a better job at this. I had bought a refurb iPhone 5S (as I was still with Freedom and that phone works with Freedom) to see if I would like Apple. That phone got dropped a few times without damage, other than a small dent in the metal. So I upgraded to an SE with more memory. I set up the phone, and within an hour or so, everything that was on my old iPhone was on the new. This wouldn't happen with Android, not to the same extent anyway.
Just my 7 cents worth. I realize that there are a lot of Apple haters out there. But since I already own an iPad and MacBook, might as well as finish it off with a decent iPhone.
Oddly, I wear a Moto 360 watch. Works really well with the iPhone. I tried using the iWatch or whatever they're call, and simply didn't understand it while playing with it. The Google Wear though, it's awesome.
07-07-2017 05:29 PM
@IWIK wrote:
BlackBerry powered Android for me.
@IWIK I think technically it would be an "Android-powered BlackBerry Mobile smartphone device"? 🙂
@will13am wrote:In this offer of preference, Android, flip phone, no phone, iPhone.
@will13am ^^^^^^^^^^^^^ yes. this. 900%. Well done.
07-07-2017 04:47 PM
Different strokes for different folks. If you don't need tons of flexibility and customization, iPhone is just fine. I've used both over the years, currently using Android, but I'm perfectly willing to consider an iPhone either.
07-07-2017 12:50 PM
07-07-2017 12:46 PM
@Samianauman although I support your statement of Android, you can do all those things on an iPhone also. You just do it via different methods.
I've used both platforms, and while centralized iTunes environment on Apple is great for some people, it doesn't work for me.
Don't claim falsehoods about devices that simply are not true.
07-07-2017 12:42 PM
it also depends your home environment, ipad, imac, icloud....if everything else is apple then iphone, but...since you are asking that is probably not the case. personally android, but you apple users would say go apple. the choice is yours. seee if you have a friend with an old android or iphone that you can test out...
btw what are you currently using?
07-07-2017 12:37 PM
07-07-2017 11:58 AM - edited 07-08-2017 12:35 AM
In this order of preference, Android, flip phone, no phone, iPhone.
07-07-2017 11:54 AM
Best do some research; for example http://www.techadvisor.co.uk/feature/google-android/android-vs-iphone-which-is-best-3625657/
Will this be your first smartphone?
07-07-2017 11:39 AM
07-07-2017 11:03 AM - edited 07-07-2017 11:04 AM
IPhone you can't even change custom ringtone or download songs or movies and lots of other stuff
And android its on your finger tip.
07-07-2017 11:01 AM
Android all the way
07-07-2017 10:58 AM
