IMessage
04-11-2024 01:55 PM
Switched over to Public Mobile and my phone number can’t be verified.
says there is an error. I have tried resetting the phone and doing network resets.
any advice
Phones
04-11-2024 03:17 PM
This worked for me too, Op make sure you have them refresh your line. They did it for me last night and iMessage only started working today. I had no sms for 6 days I figured they would fix the issue without notifying them as it has been happening to alot of people lately but that was not the case.
04-11-2024 02:11 PM
I had the same issue last week when I ported over from Bell. Wasn’t resolved until Monday night. They had to “refresh my line” twice on their end and then I had to turn iMessage and FaceTime off, and then do the reset network settings. When I turned it back on my number automatically appeared under the phone settings which then allowed me to select it for iMessage and FaceTime.
04-11-2024 02:05 PM
PM has some issue with text for new subscribers:
https://productioncommunity.publicmobile.ca/t5/Announcements/Open-Issue-Trouble-using-iMessage-amp-F...
PM can reprovision the account and fix the issue, please engage them by opening a ticket:
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
04-11-2024 02:00 PM
@Mike1099 This is public mobile issue . pM is aware and working on a fix . But best to let support know your one of the ones affected
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
