IMEI Compatibility Check for Samsung Galaxy S10 (SM-G973U1)
Vic08
Hi there,
I’m looking to switch to Public Mobile and want to check if my current phone will work with full service, including VoLTE.
Here’s my phone info:
Model: Samsung Galaxy S10
Model Number: SM-G973U1 (US unlocked)
Can someone confirm if this phone can be used on the Public Mobile network without any issues?
Thanks!
8 REPLIES 8
@Yummy @hTideGnow
My bad...my Samsung S9 is with Virgin Plus and not PM.
@hTideGnow wrote:
@BKNS27
from what we understand, the VoLTE toggle usually is hidden by Public Moble
So, check if the VoLTE setting is there or not is not a way to confirm if the phone can use VoLTE or not
Checking on compatibility site and phone settings aside, the person can make a call and check to see if the phone stays connected to LTE during calls. That will tell if VoLTE is being used.  Someone thinking about joining Public Mobile can borrow a friend's Public Mobile sim card to check.
@BKNS27 wrote:
@Vic08
I have the Samsung S9 and it does have VoLTE settings.
Where exactly do you see that setting?
@BKNS27
@Vic08
Yummy
I have S10 and it works just fine. Through PM site I confirmed it is VoLTE ready even though I do not see VoLTE option in phone's settings.
slusagm
remove your IMEi #, scammers can do something with it
a quick check with PM's checker shows it will be compatible with PM's VoLTE..  So, you should be ok
hairbag1
@Vic08
it's not on the Public Mobile whitelist of VoLTE enabled cellphones so you should upgrade to a new model for reliabilty on Public Mobile network, although it shows as VoLTE enabled on checker.
added...
here's the latest and greatest VoLTE checker...
https://www.publicmobile.ca/en/get-help/articles/volte
