I would like to upgrade my cell phone plan
KB8
I will upgrade my subscription plan. Will I lose my pre-authorized, loyalty and referral rewards?
@KB8
You can freely change plan and it wont' affect your current rewards, also confirmed by Community Manager here:
https://productioncommunity.publicmobile.ca/t5/Announcements/FAQ-amp-Troubleshooting/td-p/986594
Will I be moved to the new rewards program if I change my plan?
Changing your plan won’t automatically transfer you to our new Public Points rewards program. If you’re currently on our legacy rewards program, you will continue to stay on it. However, we encourage you to explore Public Points, as it opens up even more opportunities for savings.
Abheer
Hi there @KB8
No, you will not lose any rewards if you upgrade your plan. If you are with the old rewards program, the best advice I can give you is to not switch to the new points program.
Have a nice day.
dust2dust
No. Be sure to choose change at next renewal. There's no pro-rating here.
