10-28-2023 01:06 PM
I want to move my number to a different carrier, I haven't received the text message to do so yet
10-28-2023 01:32 PM
with porting out, you can also submit ticket with agent on PM side and confirm if they ever receive the porting out request
please submit ticket here
10-28-2023 01:20 PM
I submitted my information yeah, I was told I would receive a text from public mobile I would need to reply YES to, I never received it
10-28-2023 01:19 PM
the most important thing to remember is to keep the old provider service active, their Sim card in your device, then when you receive the port authorization request, you must reply yes within 90 minutes
10-28-2023 01:15 PM
Did you start the porting process with the other carrier?
With porting out it’s the other carrier that needs to start that process. You need to provide them with the account number from PM along with the number you are wanting to port. If you’ve already done this, reach out to the support team for the other carrier and make sure that they’ve started the porting process.
10-28-2023 01:13 PM - edited 10-28-2023 01:14 PM
Are you transferring to or from Public Mobile?
If you're transferring TO Public Mobile and the text to your other carrier didn't come through, I'll send you the porting number to get help.
If you're porting FROM Public Mobile TO another carrier, it's up to the other carrier to do it.
