07-26-2022
10:09 PM
07-30-2022
02:18 PM
Dunkman
Hello,
My plan cycle just renewed yesterday (cycle july 25-august 24). My plan is 10.5G but my usage says I already used 5.63GB (4.87GB) however I barely used my phone and I don't see this reflected in my usage history. Could someone look into this. Thank you in advance.
Regards,
Nicola
07-26-2022 11:07 PM
@nj2004 wrote:Hi, I seem to be going in circles with the chatbot. How do I log this?
use the easy way then, direct message:
07-26-2022 11:03 PM
07-26-2022 10:59 PM
@nj2004 wrote:Unfortunately it didn't work. Appreciate your help though.
@nj2004 No worry, it's time to get PM Support involved then:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-26-2022 10:51 PM
07-26-2022 10:12 PM
@nj2004 wrote:Hello,
Regards,
Nicola
Maybe it didn't reset with yesterday's renewal? Open a ticket using the chatbot. Go here for information how. https://www.publicmobile.ca/en/on/send-us
07-26-2022 10:11 PM
@nj2004 There were reports that the browser cache might be the reason that it is not showing the most updated counter
Try to login from a Incognito windows and see if it showing the true usage. Or try using a different browser (Edge/Chrome/Firefox)
