I paid for one GB Data and was charged twice
Zal1
Hey @ChuckYeah , Appreciate your enthusiam but there may be no need for the moderators. More info from the customer would could lead to a better solution. Robot Very Happy
will13am
@Zal1 , one way to triage this situation is to look at account funds which shows in the overview tab.  If you see $30 there and also the add-on which was purchased, then you were charged twice.  Because of the two step process in purchasing an add-on, it is quite easy to top up twice.  The money won't be lost.  It will be available for the next renewal or add-on purchase.
ChuckYeah
Send a ticket to a moderator.if the ticket does not work, send a private message at the contact link below. Best to ask to have the funds applied to your next renewal as the refund will likely take that long anyway.
Creating a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Spoiler
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
@Zal1 I would check to see if there is an extra $30 in your account balance. If that's the case, I would just leave it and use it towards your next renewal.
The add-on has been added correctly?
I would also check using your online banking to see if one charge might be a posted charged and the other a pending charge. For a short time, it is possible to see a duplicate for the same transaction.
ShawnC13
@Zal1are you able to post a screenshot of your payment page (with personal info removed) so we can see what has gone on.  So you were charged $60 for the $30 addon?
