09-04-2023
11:40 PM
09-04-2023
11:49 PM
computergeek541
Hello!
I tried reaching an agent but not working. I have 2 issues:
1. I need to change my email address since I used a friend's email because the account I created using my own email it didn't work and not doesn't allow me to add my actual email to my account that I have finally been able to activate.
2. I need to change the method of payment since I used a friend's of mine credit card and I want to replace it for my debit card, which I tried and didnt work iether.
Please help!
My Account
Payment
10-28-2023 05:44 PM
There is a page under accounts that will allow you to change it
09-05-2023 03:51 PM
Not sure what's going on with this thread.
Do you use any other online sites that use credit cards? Might your bank be able to tell you if it is able to do online transactions? Is it from a Canadian or American bank using a Canadian or American billing address?
09-05-2023 03:48 PM
I got this message: Access Denied
Link not working
09-05-2023 03:47 PM
HI @aurelina
then it should work. But adding/updating card sometimes is tricky here
Please check if your name and address on PM profile page are updated and match what is on your Visa Debit. Go to Profile page on My Account, click update on the name to get the address and postal code
09-05-2023 03:47 PM
didnt try before
09-05-2023 03:46 PM - edited 09-05-2023 03:47 PM
And you see a Visa logo on your card? Have you used it for other online purchases?
09-05-2023 03:45 PM
Visa debit
09-05-2023 03:44 PM
09-05-2023 03:43 PM
Well, mine it should work since not Simplii as you perfectly clarified. Thank you!
09-05-2023 02:55 PM
What do you mean there is no such thing? Your card has no form of bank logo on it?
Simplii is a form of a bank. A subset of CIBC. But there have been reports that it doesn't work here.
09-05-2023 02:50 PM
Well, the first part was solved thanks to a very efficient agent. I am still waiting for an answer as per the debit card, there is no such thing: simplii, it is another bank.
09-05-2023 10:00 AM
lol What's regular? 🙂 When you go to enter a new email address in that screen do you get errors? Or do you get to that screen at all? There are some limitations to what the email address can contain. I wonder if you could try a different email address. We all have multiple email addresses right? 🙂
We've established it's a debit card. You've also said it has a Visa logo on it so then we've established it's a Visa Debit. So the next thing is what is the brand or the bank or what company name is on it? There is a possibility that the name Simplii does not work here.
09-05-2023 08:03 AM
regular email
it is a debit card
09-05-2023 12:14 AM
1. How long is your email address?
2. Is it a Simplii card?
09-05-2023 12:11 AM
1. I tried exactly what you have mentioned.
2. I entered the info but gave me an error even though it is a visa card.
09-05-2023 12:05 AM
1. Are you able to log in to your account? The email address is just a login id? You should get the 2fa code as a text. Then you can go in to the profile and manage eversafe id and change your email there.
2. If you can login then go to payments and manage my subscription and find your way to putting in a new card. Type it all in manually. If it's a Simplii card then there seems to be some issues with that brand. Maybe it's been fixed since.
09-04-2023 11:57 PM
The debit card i tried has a visa logo on it. Thank you I will reach them.
09-04-2023 11:54 PM - edited 09-04-2023 11:55 PM
@aurelina wrote:I tried reaching an agent but not working. I have 2 issues:
For payment, Public Mobile doesn't accept debit cards unless there is a Visa or Mastercard logo on it.
As the chatbot is giving an error message while you're tryijng to open a ticket, please send a private message to CS_Agent. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
