04-21-2023
05:08 PM
04-21-2023
10:18 PM
computergeek541
I've tried entering the public Mobile APN and still I cannot connect.
This isn't a new sim, It was working on my lgg8 but I can't get it working in the pixel 6,
If there is a tech support public Mobile please help
04-21-2023 08:09 PM - edited 04-21-2023 08:13 PM
Sounds like either your SIM isn't provisioned for the network, or your new phone doesn't work at all. Can you try your SIM in another phone to confirm? Also try another working SIM in your new phone.
04-21-2023 06:45 PM - edited 04-21-2023 06:52 PM
Pixels automatically provide the correct APN settings...
all you need to do is a network reset.
open settings
scroll down to system
tap on reset options
tap reset wifi,mobile & Bluetooth
tap reset settings and restart
if it's still not working after that then there are other issues involved
the Canadian model # for pixel 6 is GB7N6
04-21-2023 06:00 PM - edited 04-21-2023 06:03 PM
Maybe try putting your Sim card back in your old phone and make a call to ensure your Sim card is still working. Then put it back in the pixel 6a and see if that forces a reprovisioning of your Sim card for the pixel 6a?
Edit:
Mind you your LTE signal is poor at -114dBm. Try 3G as suggested to see if you get service. Your 4G LTE signal may be too poor to maintain a connection to the network.
04-21-2023 05:58 PM - edited 04-21-2023 05:59 PM
04-21-2023 05:58 PM
You should remove your second image as it contains your IMEI. Edit your post by clicking on the arrow on the right side of your post and then delete the image in your profiles image library.
04-21-2023 05:55 PM
@Dennisverma123 you mentioned that this is an old Sim card. How long ago was it last use? If it’s been deactivated for over 90 days the Sim card is no longer valid and you will need to get a new one.
04-21-2023 05:44 PM
Thank you I put in the IMEI and it's not blacklisted or stolen
04-21-2023 05:42 PM
It's just a thing to rule out. Try it anyway.
04-21-2023 05:40 PM
It's open box from best buy. Not third party seller, from bestbuy itself
04-21-2023 05:38 PM
Is this a new phone? Or did you buy it used? Just to rule it out, have a look at devicecheck.ca.
04-21-2023 05:36 PM
Thank you for helping me with this. I switched to 3g and turned on airplane then turned it off and when trying to call someone it says network not available
04-21-2023 05:32 PM - edited 04-21-2023 05:36 PM
Let's focus on talk and text before data. Can you then try 3G as suggested. Maybe there's a 4G problem in your area. Also, go in and out of airplane mode to reconnect things.
Adding - volte provisioned indicates that you got volte. Nice. How about a full power off restart.
04-21-2023 05:32 PM - edited 04-21-2023 06:20 PM
L
04-21-2023 05:28 PM
Public Mobile doesn't offer 5G so you want 4G LTE/3G. Check for VoLTE to have been provisioned by checking your IMS registration. Dial *#*#INFO#*#* on your phone apps dialpad. If so then you would only need 3G if you cannot connect to the 4G LTE network.
04-21-2023 05:28 PM
I set it to LTE still no calling or mobile data
04-21-2023 05:25 PM
The plan doesn't affect this. Yes, make it the one step down to 4g/lte and others. Don't leave it at 5G.
04-21-2023 05:25 PM
04-21-2023 05:22 PM
Thank you but the preference selection on the pixel is 3g LTE and 5g . It defaults to 5g should I change that? My plane with public Mobile is 4g if that matters
04-21-2023 05:21 PM
APN is just for data. Did you try the 4G etc setting suggested?
04-21-2023 05:19 PM
It was not, I must have put in old data, for example the port was 80 not 8799 and the MMS proxy was 70. Something.
I changed it all to your screen and still I have no connection. No text or talk
04-21-2023 05:14 PM
04-21-2023 05:11 PM
@Dennisverma123 is voice working? just want to confirm it can connect to PM network
for APN , compare and chexk
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
