06-30-2020 02:32 PM - edited 01-05-2022 12:20 PM
Hiiiii so I moved about a month ago. I've had this issue before but it was a simple fix. All I had to do was change my address to my new billing address. This time I thought it was a banking issue because it told me to call my card provider. I was on the phone with them for 30 mins and we tried a million and one different combinations of my address and nothing is working. None of my payments are going through. Help.
06-30-2020 07:39 PM
Hello, it is certainly not a problem with your credit card provider, but it could be an issue with the address on your card not matching that of public mobile. I suggest retyping in your entire information section with a credit card statement in hand, and copying exactly what information is present on the form. Lookout for added spaces, case of letters, and dashes or slashes. Also try taking the card off the account, clearing the cache then readding the card. Best of luck!
06-30-2020 02:51 PM - edited 06-30-2020 02:55 PM
Follow these steps to correctly update your billing address to be accepted for payments:
Once added successfully test your card by adding funds to your account to be sure your card will work. The funds will be used to pay for your next renewal. Check back if this didn't work.
06-30-2020 02:50 PM
@Emmav7288 As far as I know you just have to make sure that your address matches exactly as the information of your CC, so make sure your CC has the same address as the one you are at now or trying to change to.
06-30-2020 02:46 PM - edited 06-30-2020 02:47 PM
contact customer support here if you still can't get it working
(use the chat bubble options, then click "submit a ticket, click me" option)
https://publicmobile.ca.ada.support/chat/
make sure to check your inbox(top right corner envelope icon) periodically, for a message
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM PM EST
