Change number failed
SG7
I need to change number today and it says number changed failed.
Please do help
12 REPLIES 12
Daps
@SG7 If you look at your usage history after logging on your account, you may be able to see your phone number that was in use. Your phone number is displayed in the text and call logs.
SG7
Thank you
@SG7  There are 2 ways to contact the Moderator Team( PM customer service):
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
SG7
SG7
What's best way to reach customer support
@SG7 I don't think theres a place to see that.
SG7
Where do I check when it was last changed in account?
Sorry @SG7 the system will not allow you do it twice in a cycle. And there isnt a workaround. Stay safe. Are you trying to transfer/ port a number from another provider?  Thanks.
SG7
Yes, I believe I did it once but more then 30days.
It should show in account when it was done
ShawnC13
Please do help
You are allowed to change your number once every 30 days.  Have you already done a number change recently?
Jb456
Have you recently changed your number? You're allowed one change per 30 days.
Orange arrow in your account.
gblackma
@SG7  do you mean change your number from within your self service account?  It can only be done once per 30 day cycle. If you already did it, you have to wait for your next cycle. Stay safe.
