11-24-2022 11:48 PM
I just signed up for public mobile. Completed the SIM card application. Sent for phone number from old provider. Thought of was complete. An hour later, received text The message was sent to authorize number transfer. We have not received your response. To reinitiate the request reply one to text and a new message will be sent to authorize number transfer. Now there is no more message. Am I done done and can I put my New PM card in my phone or is this process not completed? Thank you for your help.
11-25-2022 02:34 AM
If you replied to text first text with YES then porting will be proceed.
You can leave the old SIM in your phone and continue to use your phone until the porting will be switched to the PM SIM (this could take up to 90 minutes).
Once the old SIM stopped working then you can switch to the PM SIM.
11-25-2022 12:00 AM
@gpixel4 wrote:that's pretty neat that PM has added that option to reinitiate the text to port. if you replied 'yes' to the text message you're good to go and you can install the PM sim. after installing the sim reset your network settings and restart the device
The appears to have been a folow up text message sent by the old carrier that they weren't allowing the number port because they never got the "yes" message.
11-24-2022 11:58 PM - edited 11-25-2022 12:00 AM
that's pretty neat that PM has added that option to reinitiate the text to port. if you replied 'yes' to the text message from your old provider. you're good to go and you can install the PM sim. after installing the sim reset your network settings and restart the device
11-24-2022 11:58 PM
@BigB778 wrote:I just signed up for public mobile. Completed the SIM card application. Sent for phone number from old provider. Thought of was complete. An hour later, received text The message was sent to authorize number transfer. We have not received your response. To reinitiate the request reply one to text and a new message will be sent to authorize number transfer. Now there is no more message. Am I done done and can I put my New PM card in my phone or is this process not completed? Thank you for your help.
The Public Mobile chatbot should e used to contact a customer support agent. No, the number porting process isn't complete. Link to chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Your old carrier's SIM card needs to be left in the phone so that you can reply to that text message.
11-24-2022 11:51 PM
@BigB778 is your old provider sim card and service still working? if so, the porting is not completed
There is a porting support group you can call and talk to live support. I will message you the number to you Community inbox. Please check and call them tomorrow morning (it is now closed)
