07-26-2022 03:53 PM - last edited on 07-26-2022 06:27 PM by computergeek541
I just activated a Public Mobile SIM and got a new phone number (was not ported from another carrier). The phone will make calls but will not receive calls...when I try to call it I get a message "6UT1, the number you have called is not in service". How can I get this resolved. I want to be able to make AND receive calls on this phone! HELP
Thanks
07-27-2022 07:06 AM
@tochowchick if you have another phone atound, put your PM SIM card there and try. This could force a sim re-provision and that could resolve the issue.
if still fails or your don't have a 2nd phone to test, open ticket with PM support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-27-2022 06:41 AM
Thanks for both of those suggestions...I've tried them both but still not receiving any incoming calls...outgoing fine. Very strange and frustrating!!!
07-26-2022 05:24 PM
turn off device take out SIM card and re-enter back SIM card on.
07-26-2022 03:58 PM
Try restarting the phone to see if that helps.
07-26-2022 03:56 PM
I should add...that when I sign on to my account it says it's ACTIVE
