I have made a payment for 30 days plan but I cannot make calls
v_dontscheva
Hi, there. I disabled the autopay on the 90 days plan and chanegd my plan to 30 days one (unlimited Canada-wide calls, unlimited text and 1 GB data) and made a payment of 47 CAD. I did that a few days ago while abroad. Now, when I came back to Canada, I am surprised to find out that I cannot make calls and if somebody tries to call me, he gets redirected straight to voicemail. Please help me because I am expecting a phone call regarding a job opportunity.
rob79
You need help from the @CS_Agent
Hopefully they'll see this soon.
will13am
I suggest sending a private message to the moderator team and have them look into the matter.  If you have never used private messaging or contacted a moderator, check out these links.
http://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating/...
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
Nsk143
Did you set future date or was your plan suspended ? Or maybe it didnt go though if that's the case then you need a mod assistance
Send your email address
Phone number
Explanation of issues
Hopefully they will get back to you soon. Thx
mimmo
Can you check what self serve says your plan is and what your available funds are? Ie did the plan change take effect?
