I have been with Public since March I have a small amount of data on my plan which I've never been a
Hughie21
Never been able to use my data
Helpershelper
If there’s something wrong with the SIM card or your phone’s settings, which might be the case, it’s better to visit a physical location near you, like in a mall, so that they can check it for you. That’s what I would do.
kb_mv
@Hughie21 What kind of phone do you have?
Triguy
Make sure you have the correct APN settings.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
LovesToPM
Hi @Hughie21
Which phone model are you using?
To use mobile data, you may need to set up the APN settings.
