07-26-2022 07:09 PM
I have been charge twice on my credit card... On the 22 and on the 23 of July
07-26-2022 09:57 PM
Yes, if you are charged twice, the extra should remain in your account as available funds. PM is usually very good about this, so don't worry you'll definitely won't pay twice for nothing.
If you need to contact support, the quickest way is to send a message here:
07-26-2022 07:24 PM
you activated new line and you have two charges on your credit card,
do you can login to your account maybe is there at Available Fund, then if see them money has it then left there until next data cycle will be automatically take it from there.
07-26-2022 07:14 PM - edited 10-21-2022 01:01 AM
@ClaudeBoutot123 you saw the 2 charges from the credit card? Any chance one of them just a pending charge while only one is the real charge
any chance you have 2 accounts with PM or you have made a request to change plan on July 23?
Also, login to My Account, check if you see any amount in Available Fund. If the overcharge amount is there, you can choose to let it stay and used it for next renewal.
https://selfserve.publicmobile.ca/en/account/overview
Also, check Payment History and see if it shows clearly PM charged you on the 2 days
If it is still unclear or you certainly want PM support to look into it, open ticket with PM :
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-26-2022 07:13 PM
@ClaudeBoutot123 - Did you by any chance change your plan during that time? When was you last cycle date?
