billing
07-26-2022
08:48 PM
07-27-2022
12:11 AM
computergeek541
posting 12.29 am in usage
is this afternoon or early morning
if early morning...why would my data usage be used when i am sleeping
My Account
Plans
07-26-2022 09:54 PM
@Jones2 Some phones like iPhones auto shut down WiFi to save battery when they have been locked for few hours. So that is also the possibility. Next time that happens, check the data usage right away in your phone settings to see which app used data.
07-26-2022 09:44 PM
3 dates stand out in July data used 35.64mb/ 42.53mb/ 52.36mb all while sleeping and on wifi
07-26-2022 09:32 PM
@Jones2 How much data did it use? If it's a very small amount ( >10mb), I wouldn't worry about it. iPhones force use background services to ensure connectivity with all their services.
Try turning on Airplane mode for a min and turn it back off. You will see a few MB of data available to use in Self-Serve.
07-26-2022 09:20 PM
07-26-2022 09:16 PM
my apps background is off for all,
also at that time (midnight) i would be connected to wifi and should not need to use data
07-26-2022 09:12 PM
that is what i thought,
in settings my background app refresh is turned off for all, do not have whats app
i will try and keep any eye on this
thank you for getting back to me
07-26-2022 08:52 PM - edited 07-26-2022 08:53 PM
@Jones2 Thats at midnight. Depending on what phone you have, there are some background services like iCloud. iMessage or WhatsApp that use data for several reasons.
07-26-2022 08:51 PM
close all apps before you go to sleep
and turn off your apps background
