04-11-2023 03:57 PM
I need an agent to fix the problem on Public mobile's side. Thanks.
06-16-2023 05:24 PM
@WTF666 you have been using it and data stopped working? which city you are in? what phone you have?
for the sudden plan change , did you check with PM support and have them investigate? if not, message them here
05-02-2023 08:15 PM
@monsternangel wrote:No, I use more than 1 GB but less than 2GB the plan all the time every month, til I reset my phone n things changed. I checked the data screen all the time. It couldn't be one time thing, to give then take away, it's extremely nasty business strategy.
Unfortunately, your device doesn't know which plan you have. The 2GB indicator showin the picture doesn't necessarily mean that you have a 2GB plan. That number can actually be set to anything that the device user wishes to change that nubmer to.I've look through this thread, and I haven't seen anything about which plan you have. Which plan did you sign up for? As mentioned a few weeks ago, if your plan price is $15, it only includes 250MB.
05-02-2023 07:16 PM
View your payment history from back then to now. How much do you pay at your renewal? I suspect you'll see a $10 line and $5 line.
There's no $5 512MB add-on either.
I think you need to take better control of your data usage. Turn off OS and app updates over cell. Make it just wifi. Turn off background data usages in apps.
05-02-2023 07:09 PM
Definitely not, I had no problem to go over 1GB all the time til recently. From last year 2022, black Friday or Christmas.
05-02-2023 07:07 PM
Hi, sorry, I had miss your msg. Definitely I had no problem to go over 512 MB because I had a 2GB plan. It's happening in a sudden recently that I have no change any way that how I use my data but usage use up so quick. I also added a extra 512MB for $5 after couple days I post my msg and then it used it again so quick, three days ago. It definitely doesn't seem right. Looking forward for your help, thanks.
04-11-2023 11:18 PM
Don't rely on the data counter on your phone, login to your PM account in Incognito Mode. My assumption is that you're on the $15 plan which has always had 250MB of data; the 2GB was likely holiday bonuses, possibly stacked from multiple years.
04-11-2023 10:59 PM
Thanks for the link. I hope I can finally get to an agent to deal with the issue.
04-11-2023 10:45 PM
04-11-2023 05:43 PM
Hi @monsternangel the 2GB promotion you mentioned probably is the Christmas bonus. It is a one time add-on bonus, not monthly
04-11-2023 05:42 PM
It was definitely 2 GB data after 2 years within public mobile they gave me from the black Friday/xmas promotion. My data usage screen on my cell shows 2 GB but it stop at 250 MB now, n yes, I log in to my public mobile account n saw 250MB use up, but that's not right. Suppose be 2 GB.
04-11-2023 05:15 PM
If you are on the $15 plan with 250mb plus the More is Merrier promo with 2gb of data and 500 minutes of LD calling…you may have used it up.
Just login to your account and check your data usage.
04-11-2023 04:09 PM - edited 04-11-2023 04:12 PM
@monsternangel what plan do you have ? $15 plan? $15 plan only comes with 250mb. Maybe the 2GB just an add-on bonus?
Login to My account using Incognito/Private/See secret mode and see if you see any 2GB add-on
Also, after you reset the phone, maybe you used some data for app download and is update??
if you really need agent to confirm what you had before, submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
04-11-2023 03:59 PM
First confirm your actual usage:
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Data cannot just disappear after resetting phone unless phone did massive download after reset...
04-11-2023 03:59 PM
contact an agent to help you
