06-16-2025
11:23 AM
06-16-2025
01:39 PM
computergeek541
Hey everyone,
I changed my phone number last week through PM website and I forgot that that phone number is connected to many services i use. Is it possible to get it back somehow if it's still not taken, because i called it for couple of days i dont think anymoby has it yet, so just need to know if i can get phone number i had a week ago back.
Thanks in advance.
06-16-2025 11:27 AM
@discipline wrote:Hey everyone,
Thanks in advance.
Hello @discipline
Since you have the ability to log in, THIS is the proper way to create a ticket to chat with a CS Agent to look into this matter.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
06-16-2025 11:27 AM
why can't you just work on changing those service to the new number? Bank is usually easy for phone number change. Might be harder for email service like Google or Apple , as they have not person to talk to , but it is still possible
if you really need your old number back, ask PM and they can still reverse the change. Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
Or you can also message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
06-16-2025 11:25 AM
HI @discipline
PM support agent could help. Please submit a ticket as early as possible
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
