06-16-2025 11:21 AM
Been trying to port my number out with pm to my new carrier the sgrng deleted the esim so now I am unable to get request can some on manually appve the request pls
06-16-2025 11:36 AM
@James61722 wrote:Been trying to port my number out with pm to my new carrier the sgrng deleted the esim so now I am unable to get request can some on manually appve the request pls
Hey @James61722
This is what you do. If you still have the PM app on your phone, open it, sign in and go purchase an eSIM. Don't worry, it will be $5 but when you get to the checkout, it will be free. Reinstall the eSIM and get your PM services back. Then contact your other provider and ask them to try the port request again.
06-16-2025 11:24 AM
where you are porting out to? unless you are porting to Koodo or Telus, then you can port without an active sim, if you are porting elsewhere, you need to get reactivate a sim card to get the port approval text
06-16-2025 11:23 AM
HI @James61722
you deleted the esim too fast. You need to get a text from PM and approved it before you delete it. I doubt there is much you can do other than to get a esim or physical sim back. But ask PM support and check
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(use email to get the 2FA code, click Didn't receive code or Resend code and choose Send email)
If any issue with ticket submission, you can submit ticket by direct message:
