01-23-2022 03:03 AM
Can't login to my account online. I think the email is wrong with my phone number. What is the customer service number to call n talk to someone to solve this?
01-23-2022 11:43 AM
Do you at least remember your password? If yes, try all possible email you have until you get to the correct one.
If that does not work, you will have to contact CSA through personal email as per provided instructions.
PM has no customer support phone number; only help provided is from other customers like you or through email to CSA.
01-23-2022 07:07 AM
You can determine which is the correct email address by using the "forgot your password?" option on the login page and entering any of your email addresses. The one which is registered with public mobile will prompt you to receive a forgot password link.
If you activated in-store, a self-serve account would not have been created. In order to create one, click here:
01-23-2022 05:01 AM
@Ravenchk There's no customer service number. You need to contact thme using methods shown above.
01-23-2022 04:15 AM - edited 01-23-2022 04:20 AM
Look through your email accounts to see if you can find the Welcome email from Public Mobile. That will be your self service username. If you cannot find it then contact a CSA.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
