4 weeks ago - last edited 4 weeks ago by computergeek541
I have a OnePlus 11 phone and for the last 30 days, I haven't been able to send MMS or RCS messages through my Messages app. Is there a way to fix it?
3 weeks ago
Thank you SO SO MUCH!!!
It worked!!!
4 weeks ago
Along with checking the APN. Check to see if Cellular data is enabled.
4 weeks ago
did you just update the OS to Android 14? There has been some issue with OnePlus after the Android upgrade
With OnePlus, there might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
4 weeks ago
@Yossy107 - You may need a new APN as most one plus customers here at Public Mobile need the new MMS APN:
Pasted from here: https://publicmobile.ca/en/ab/get-help/articles/set-up-data-on-an-android-phone
Next, check your APN settings (Android Phones Only):
