03-08-2024 08:17 PM
Hi, as of about 3 days ago I can no longer send or receive images when I text. Normal texting works fine.
First time ever having problems.
Phone is an older phone - Samsung Core SM-G386W
I have the $25 a month unlimited voice and international text plan.
My plan shows I have lots of data available (though I don't think that matters).
I have tried restarting the phone. Left it off overnight. No change.
Any thoughts on how I can get this working again?
Thanks in advance.
03-09-2024 09:36 PM
03-09-2024 09:35 PM - edited 03-09-2024 09:36 PM
@Hammy2
Slide your finger down the display starting from the top edge of your phone. Press the settings icon.
Press More networks.
Press Mobile networks.
Press Access Point Names.
delete that current PM APN and add new
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
03-09-2024 09:32 PM
i have had no luck with these settings
03-09-2024 09:22 AM
@Hammy2 Under Mobile Networks look for Access Point Names. That's the APN.
03-09-2024 09:01 AM
Thanks Phil_Adelphus, I had tried that. Searching APN returns "No Results Found".
03-09-2024 06:01 AM - edited 03-09-2024 06:03 AM
@Hammy2 There is usually a search function in Settings. Just enter APN in the search box. If you're looking for reset settings then type in reset. Whatever you do don't select factory reset or it will wipe the phone!
03-08-2024 08:47 PM
7m ago
Thanks for the prompt reply.
I can't seem to find where to reset this. Tried googling it but no luck. Any thoughts?
03-08-2024 08:37 PM
03-08-2024 08:20 PM
The MMS issue is related to the PM announcement about MMS. The solutions are as per announcement:
03-08-2024 08:20 PM
your phone was released on 2014 and very likely affected by this announcement:
you can try this: click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
