I can't receive incoming calls
MuChen
After I transferred to Public Mobile. Suddenly, I can't receive incoming calls.
  • I tried restart iphone
  • reinsert SIM
  • Airplane mode
Is there a way to find a representative? I can't submit a ticket... I missed my medical phone call.. I can't believe what kind of issue they are having
TheSterlinger
There are a couple things you can try. First you can try resetting your network. Go to settings then general scroll down and click transfer to new iPhone or reset. Press reset network. Restart your phone and see if that works.
If it doesn’t work then you can submit a ticket to a Public Mobile CS agent tell them what’s happening and ask for a network reset with the link below.
MuChen
Thank you very much. I'll wait for it.
@MuChen
Check for any outages in your area:
https://istheservicedowncanada.com/status/telus/map
hi @MuChen
the porting was not completed
check with PM porting support team and confirm.   I will send you the number to PM Porting support team  Please check your community inbox
