3 hours ago
Why can’t I port my number out of public mobile? Public mobile keeps telling my new carrier that my number is inactive.
30m ago - last edited 28m ago
@Dynac wrote:The eligibility check says my number is ineligible for porting
@Dynac That check is to determine whether you can port your number from another provider TO Public Mobile, not from Public Mobile to another provider.
If your Public Mobile service is still active, I'd recommend using out this cycle's service (since you've already paid and there's no refund once you leave for partial services), then a few days before the end of this cycle, complete the port to another provider.
Bear in mind, porting to a new provider is ALL ON THE NEW PROVIDER to manage. The provider you're leaving has no skin in the game so be sure to stay atop of the new provider's processes to ensure it occurs.
Best of luck!!!
32m ago
Sorry to hear. Your number are the roughly 1% that can’t be ported.
You will need to pick a new number but remember to login to your account online or website and unsubscribe to cancel your PM account.
2 hours ago
2 hours ago
If your account is active maybe try to see if your number is portable:
It would be weird if it can’t then contact a CS_Agent to help you with the issue.
2 hours ago
@Dynac When you initiate the port in request through a new carrier, you should get a text message on your Public Mobile sim to confirm port in request. You must reply to that text message to complete the port in request.
Are you able to send/receive text and calls at the moment on your Public Mobile sim?
2 hours ago
@Dynac that should work, strange. Reach out to an agent by clicking the orange round circle in the bottom right corner and type: Customer Support Agent, they should be able to help you
3 hours ago
My subscription just got renewed yesterday. The PM app says my account is active. I can call/text/use data with no problem.
3 hours ago
@Dynac have you gone into your PM app or the website to confirm your account is still active? Can you call out and text with your PM SIM? Numbers cannot be ported out from inactive accounts
