04-02-2023 11:03 AM
I suspended my account for two months as I was out of the country. I reinstated my account. My profile says it is active. I can't phone outgoing, it says call ended. I can't receive calls, it goes straight to voice mail. I can't text. I have turned the phone off and then on again. I removed the battery and reinserted, but still nothing works
04-02-2023 12:10 PM
You took the battery out?
Do you mean you took the SIM card out?
04-02-2023 11:56 AM
I took the battery out and back in. I reset the network. All working now. Thx
04-02-2023 11:19 AM - edited 04-02-2023 11:21 AM
Might be worth checking with the Customer Support Agents if you've tried the fixes we've suggested and still no service.
(Adding: did you try the PM SIM card in another device to see if it has service with another phone...)
04-02-2023 11:16 AM
I didn't take that phone with me.
04-02-2023 11:13 AM
@ClarePhone is data working?
did you use your phone with another sim card when you were out of the country?
Try this, click Reset all networks first and it might resolve the issue with just that click
If not, check if your have any VPN profile setup, delete them if so. ( this is very common cause if another overseas sim card was used, somehow some VPN profile setup with that sim)
04-02-2023 11:07 AM
does the phone have dual sim slots ?...if so try the sim in the other slot.
04-02-2023 11:05 AM - edited 04-02-2023 11:06 AM
Try resetting network connections and ensure you are connected to the Public Mobile network under network connections.
Try the Public Mobile SIM card in another device to see if you have services.
Adding: While you're at it, be sure to tap this area on the self-serve landing page to ensure you're not viewing cached (outdated) information.
