I can't login
06-24-2023 05:28 PM
I tried to login to my secondary account to update my visa card information and it says the email is not valid and i can't log in.
I don't remember the account number and I tried to resign in and reset the email address and the server is all confused. I am not sure what to do now.
My Account
06-24-2023 05:48 PM
@sfy never said anything about a single login for all, I was just saying the system could be less clunky managing them, so users don't face the issues they are.
06-24-2023 05:44 PM
@XionBunny Managing multiple accounts will always require access to each account. There will never, I hope, be single login for multiple accounts.
06-24-2023 05:41 PM
I was able to reset my password
06-24-2023 05:35 PM - edited 06-24-2023 05:35 PM
Good luck, they really do need to add features to allow customers to manage multiple accounts, it would go a long way to easing some self-service issues here, several other customers have problems like you.
06-24-2023 05:33 PM
@Yoon1x - have you created the EverSafe login info for this 2nd account. Remember here, each account needs it's own unique email address.
There may be cache issues if you logged into another account with the same device and browser you are using. So try another device or browser. OR, open a tab in incognito mode and try again.
06-24-2023 05:32 PM - edited 06-24-2023 05:32 PM
@Yoon1x Try again but once you put in the email you know to be correct tap forgot password then verify thru email create new password and then log in again and have code sent to phone verify and you should be logged in
