I can't login in nor does *611 work for me
Nickname141
I tried to pay my cellphone build as I always do through calling Star 611 but it hasn't been working and I called over 20 times so I try to use a site but decide says forbidden AI and then I try to use mobile app but it says in maintenance what's going on I need help
hairbag1
@Nickname141  @Katie822
everything is back up and running as expected now.
Neil11
If it is still not working then try contacting CS_AGENT. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
PM is under maintenance so try again in the morning.
Nickname141
Ok so it just the service public mobile then I guess but this never happened to me before as it usually go though the 3 time I call and do you know how to contact them or is this community site all we have
Katie822
Same here for the rest apart 3 hrs
