I can't login I need help asap
sheilacram
I can't login or reset my password.
it show that the page doesn't exist
8 REPLIES 8
Use computer to log in. It definitely works, I just tried to confirm.
@sheilacram wrote:
nothing works . Is there any way to reset the account ?
HI @sheilacram
Please message PM CS agent and they can assist resetting it
sheilacram
@sheilacram wrote:
doesn't work
HI @sheilacram   do you mind to provide a screenshot?
and you used different browser?
sheilacram
doesn't work
walker1
@sheilacram
All you have to do is login to your account using a different browser in incognito mode or private mode and you'll be fine. Just try again.
@sheilacram
did you login to https://selfserve.publicmobile.ca/ ?  do not use bookmark, just click on that link
try to press Back and try again
or try using Private/Incognito mode to login
Haiggy
I'm not sure how you got there, but try https://selfserve.publicmobile.ca/
and to reset your password: https://myaccount.publicmobile.ca/en/forgot-password
