No get sms
Alireza2020
I transferred my number to public mobile 2 weeks ago.
But I don't get any messages or calls even verification code.
Why ?
When I'm going to login it needs code but I resive nothing.when I go for support team says go for login?!?!?!?!?!?!
hi @Alireza2020
you didn't get any calls at all?
It sound like the number not ported yet.  But check with PM porting support team and confirm.   I will send you the number to PM Porting support team  Please check your community inbox
Neil11
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
@Alireza2020
send  a  private message   To CS_Agent
