01-06-2022
12:57 PM
01-06-2022
11:21 PM
computergeek541
I just switched from chatter to public and I'm able to make outgoing calls but not able to receive incoming calls incoming text message and I'm not able to send outgoing text messages
01-06-2022 01:08 PM - edited 01-06-2022 01:10 PM
you post two time keep on one post.
01-06-2022 01:07 PM
You will want to send a private message to @CS_Agent with your account details and they will resend the porting request for you.
01-06-2022 01:06 PM
@TT1984 Chatr?
so, are you porting out or porting in?
For porting in, there is a number to call and I can message you the number on Community inbox
for porting out, open a ticket use this direct link: https://urlshortner.tiia.ai/Lc9xk8
If you have made a request to port your number to another carrier and have not received an SMS from Public Mobile to confirm your request, please open our chatbot via this link.
01-06-2022 01:03 PM
I need to get public mobile to resend a portal request to chatter is chatter so I can confirm the number change I Is timed out on the original Request and I still can't receive phone calls or text messages or send text messages
01-06-2022 01:01 PM
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
you can do some troubleshoot your device and test
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
Good Luck and your welcome to Public Mobile
you will be very happy...with a Fabulous Service.
01-06-2022 12:59 PM
Try rebooting your phone. Power off your phone then wait a few minutes then power the phone back on.
