01-06-2022
01:15 PM
01-06-2022
02:26 PM
ShawnC13
Just activated a sim card yesterday 05/01/22 which I switched mobile number from Virgin mobile to Public mobile. 5**-***-***1. I can make calls without issues but I cannot receive and
Edited By: ShawnC13 Removed Phone number
01-06-2022 11:18 PM
@rogerpitre5 wrote:Just activated a sim card yesterday 05/01/22 which I switched mobile number from Virgin mobile to Public mobile. 5**-***-***1. I can make calls without issues but I cannot receive and
@rogerpitre5 - when changing providers and SIM cards, some troubleshooting to do to help kick start the network, try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
01-06-2022 02:26 PM
01-06-2022 02:04 PM
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
you can try to do some troubleshoot
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
01-06-2022 01:43 PM - edited 01-06-2022 02:24 PM
You might want to edit out your personal phone number as this is a public forum. Click the little down arrow, top right side of dialog box and edit your original message.
01-06-2022 01:33 PM
It does sometimes take several hours for the port to go through. If it's been as long as 24 hours since the porting was started, you should send a private message to @CS_Agent so they can look into this for you.
