04-14-2025 12:52 PM
I need help. Lately I had hard time to make a call. But today I realized that I could not make a call and receive a call. I can make a call via What's up App. Thanks. Hong.
04-14-2025 06:22 PM
@hTideGnow wrote:s10+ should not be badly impacted by the Telus change mentioned above Please try reboot phone and Reset Network settings
I do not believe that a Samsung Galaxy S10+ is able to use VoLTE at Public Mobile. As such, refarming of band 5 to LTE would have a bad effect on voice services. The extent of the the refarming of band 5 can vary and can be debated, but it can't be a good thing for any customer still using the 3G network for voice.
04-14-2025 01:11 PM
I did shutdown my phone and then restart my phone. but ...
Now I reseted my internet.
HI @Hongt
I have a hard time to ask PM support to refresh the account on the system.
Can you help me to do so?
04-14-2025 01:02 PM
I bought the phone in Canada.
04-14-2025 12:58 PM
HI @Hongt
and if same, ask PM support to refresh the account on the system
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
04-14-2025 12:57 PM
galaxy 10+
04-14-2025 12:55 PM
did you try reboot your phone? and you can use Whatsapp using Mobile Data? so data works and just not voice calls?
check Telus outage map
https://www.telus.com/en/bc/outages
what brand/model phone you have?
04-14-2025 12:55 PM
hi @Hongt
what phone do you have?
Telus is refarming all of their 850 to 10 MHz LTE B5 in their markets, mainly BC, AB, Windsor, Ottawa, GTA area Montreal, Quebec City. Bell has not done this, so it won't affect area that has Bell networks which Telus/PM use
So, if your phone has only 850 Band 5 on the phone but lacks 1900 Mhz, if your phone were bought from another country, or an imported model, then you might be impacted
On the other hand, if the phone has 1900 Mhz, or it is a Canadian/US model, it likely won't be impacted and won't see service degraded
https://www.publicmobile.ca/en/get-help/articles/850-turndown
