06-12-2022 08:05 PM
Hello,
I checked available funds, its up to 45$ now that I've basically paid for 15$ worth of data 3 times now. I've turned my phone on and off multiple times. It shows on my plan that I have data added on, but nothing is working.
I would like to reduce the amount to only 15$ again, I don't need 45$ worth of data. And I need to get the data to work.
06-13-2022 12:56 AM
Do have your data limiter enabled?
06-12-2022 08:07 PM - edited 06-12-2022 08:24 PM
@Katrininga wrote:Hello,
@Katrininga did you actually buy the add-on 3 times or just loaded the fund 3 times?
Buying add-on is a 2 steps process, 1. Load Fund, 2, Actual buying
Many people just loaded the fund and missed step 2
If Available Fund = $45, you didn't buy at all, you just loaded the fund. Go back and just buy the addon, you should then see the Fund down to $30.
Also, you can confirm this by going to Transaction history page
In case you bought more than once ( not just loaded the fund but actually bought), open a ticket with PM Support to ask them to reverse the transaction:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
06-12-2022 08:07 PM
You may have cellular turned off on your phone or the app you are trying use with cellular has been disallowed.
