I am suddenly being charged for using all my data after no problems for 2 years.
Egg1
Why am I now using too much data? I have not changed my usage.
@Egg1 - are you sure you are out of your data ?
Call 611 from your device and check your data balance. This will include any plan or addon data you have remaining on your account.
If you received texts about using up data and it does not match up to what 611 is telling you or your refreshed My Account screen (as @hairbag1 is showing), then ignore the texts.
HALIMACS
This is a question only you have control over, @Egg1
Would recommend that you Google "lower data usage" and use the many options it provides which are all settings on your device.
dust2dust
Charged? There's no charge for anything when you've used all your data.
Are you getting the text notifications from 611 about having used 75% or 95%?
_LL_
Many ways for this to happen:
A new app updating in the background
Wifi drops off when streaming a video at home
Viewing an email with large attachments
etc.
Unless you are on the multi GB plans, the only effective way to prevent it is to disable data usage for most apps through your phone settings.
If you suspect this to be an error on PM’s part, you can always send a support ticket, but I wouldn’t keep my hopes up.
@Egg1
thiss could happen, maybe apps or OS update?
how much data you have per cycle?
are your using Android?  check the Data usage page and it will give you hint how much data used and which app used the data
hairbag1
@Egg1
in settings, turn off data to any apps that you don't regularly use.
Log in on your laptop to see data availability...
