I am getting a 6ut1 error when trying to make a call
ex200167
Hello!
I don't know what to do, every time I try to make a call I am unable to. I keep getting this:
"6ut1 the number you have reached is not in service"
@ex200167  since the VoLTE, it seems like we need to include the 1 to call more often
Also, while you think you don't have to include 1, some dialer like Google dialer will actually add the 1 behind the scene
No worry about including 1, it won't make a a Lond distance call and starting charging.  We (at least most of us) have Canada wide calling, so, it won't give you extra charges
ex200167
Yeah, adding the international code works. but I just never had that issue before. What do i do for 1-800 numbers?
@ex200167 - message is usually connected to a network issue or number out of service.
Perform a Reset of your device's Network Settings and see if that helps. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
HI @ex200167
does it happen to all numbers you call? you tried other numbers?
Usualy it is just a sign of overload on the system and usually resolves within a short time.
Try dialling the full 10 digit number with a ”1” in front
@ex200167
try to reboot the phone once
add a 1 in front of the 10 digits number
