Text message, network connection problems
Johnc2780
I can't receive or send txt msgs with attached photos
@Johnc2780  - try restarting your phone.
Also, you could try toggling into and out of airplane mode.
@Johnc2780 are you using Android or iPhone?
if Android, try to clear message cache first
Next to try, download another message app like Google Message
Last, try to click Reset All Networks, it will update the APN and should resolve the issue.  (Please note it will delete saved wifi connections as well, you just need to re-join them after)
Johnc2780
Yes I am using mms  and my Mobile data is on. Also RCS doesn't work.ecause RCS doesn't work.
Johnc2780
Mobile data is on.
@Johnc2780
" txt msgs with attached photos" is MMS , you will need to turn on Mobile data to send/receive.  Although it needs to be on, it does not really count towards your data consumption.
Try it
