06-03-2024 03:14 PM
We have recently moved from Sherbrooke to Chambly and we have noticed insufficient conversion, calls such as Mobile Data in this area where we are... We would like to know if Public Mobile does not have coverage in this Area of the Country.
06-03-2024 04:36 PM
Negative, both Pixel and OnePlus Nord phones moved around chambly places and coverage was always a problem, whether close to these antennas or not.
06-03-2024 04:14 PM
Well, trying to Help the community, I have made the change, created a New APN with the configuration sent and even so, the coverage or data is still the same... I hope to have a solution soon.
06-03-2024 04:12 PM
@sary1611 wrote:The Problem may not be APN or even Network Type or in General the Phone Model
@sary1611 , do you have issues in the entire area or does it get better when signal strength is stronger when situated closer to a tower? If performance is location dependent, then it could be coverage related.
06-03-2024 04:08 PM
06-03-2024 03:58 PM
the reason I asked you to help is what I still think there is a chance that it is APN related
Many have data and MMS problem with OnePlus and ended up needing to change the APN to get it working
Of course, if you don't feel comfortable updating it, don't. But while you are out of idea and waiting for support to come back with an answer, and if you are comfortable make the change, why not
Also, it is a very safe change I suggested, I asked you to make a new profile instead of messing around with your current APN profile. If anything, you can easily change back to the original profile
06-03-2024 03:55 PM
@sary1611 wrote:So if you doubt that it works, why tell me to make that change? The same thing happens in the city, there are blind places without any connection.
@sary1611 , please don't mess around with APN settings. If you have a data connection already, creating new APNs will not improve data speed. I suggest looking at the tower map in your area to determine the coverage specific to your locale. Perhaps you are are situated in a coverage hole.
06-03-2024 03:50 PM
06-03-2024 03:46 PM
when you move around the city, any difference in terms of the connection?
I doubt it will help, but try.
Create a new APN Profile (make sure you save it correctly) and set the new one as active one:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
06-03-2024 03:45 PM
And Yes, i change Network, to 3G and Nothing Change, 4G or LTE the Same
06-03-2024 03:44 PM
My Phone Model is a One Plus Nord N20 5G, Model: CPH2459
06-03-2024 03:42 PM
OK I send a Message.. And i hope have solution for my problem !!
06-03-2024 03:39 PM
From the French Forum is my cousin, who was visiting us, and we had the same problem with 2 Phones of different Brands and Models, nothing solves the problem, the connection is lost repeatedly, not even changing or modifying the types of networks to use. I come back and repeat, we came from Sherbrooke, where everything with Public Mobile was 100%, just by entering Chambly, the connection worsened by 90%
06-03-2024 03:37 PM - edited 06-03-2024 03:37 PM
06-03-2024 03:36 PM
if you have a physical sim, try putting the sim in another phone and test. This will force a sim reprovision and could resolve your problem when you put the sim card back to the old phone
but if you don't have a physical sim, or that steps above does not work, please open ticket with PM support and ask them to reprovision your account or check if any local network issue:
06-03-2024 03:33 PM
06-03-2024 03:29 PM
It should be fine because in Sherbrooke the Service worked well and now in Chambly this service does not work, neither call coverage nor Mobile Data connection, changing the connection, 3G, 4G or 5G does not work.
06-03-2024 03:19 PM
how long you got the network issue in Chambly?
@EliecerBrito from the French forum reported poor coverage in Chambly too. I have checked and it has decent coverage there. Did you try to Reset All Networks? try changing the network mode to 4G/LTE or 3G and test if for couple hours and see any improvement
06-03-2024 03:17 PM
HI @sary1611
the coverage map shows chambly has 5G and 4G/3G coverage. Chambly is not rural, it should be ok
https://publicmobile.ca/en/nb/coverage
any of your friends with Bell or Telus experiencing the same?
