3 weeks ago
3 weeks ago
Maybe you removed the old sim too soon? It will tell you when to remove it as you need to accept conformation texts from your old carrier.
3 weeks ago
I don't have a SIM card. I use esim
3 weeks ago
I joined PM last week and transferred my existing number with them. What worked for me was to leave my old SIM card in the phone until the number porting was completed, this way I was able to still make and receive messages or calls. Every 15 minutes I would send out a text message (SMS) and when they failed to be delivered I switched to the new PM SIM card and it worked out perfectly.
3 weeks ago
HI @KenNelson
are you requesting to port your number? did you check if the code got sent to your old carrier's sim card?
and the service is working or you still activating?
if you still don't get the code and cannot login, please ask support agent to help. Message them:
