I DONT RECEIVE verification code in my email
Sans1
I have changed my password according to your system advice more than I should.....anjd STILL the MAIN ISSUE is that y our system then wants to immediately verify me( which they just did via a SMS code)
I've now:
- waited two weeks to receive a code,
- NO PHONE capacity all this time
- STOP sending me in circles
Sans1
THANK YOU THANK YOU sooooooooooooooooooooooooo much.the "clicking here' worked.
A rich blessing filled 2023 ....all year long...to you and yours
HI @Sans1   is your account suspended? you do not have an option to receive the code via email?
No need to worry, this can be fixed, open ticket with CS agent  at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Meow
After changing password one wait 20 min and try to log in again.
If you still have issue logging in, contact agent to update your account/email.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
@Sans1
I guess you need to  open ticket with PM support using Charbot and they will sort it out for you
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@Sans1 @To change ur mail you will need the help of support
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
