05-13-2023
05:23 PM
05-14-2023
10:32 PM
Dunkman
05-14-2023 05:31 PM - edited 05-14-2023 05:31 PM
@BethM1313 That's a terrible situation with the wildfires in Alberta. Good to hear support was willing to help somewhat by giving you extra data during this emergency situation.
05-14-2023 04:06 PM
Thank you for the reply.. I talked with an agent. Explained our town has been under evacuation due to wildfires since May 4 th. I explained that because we have no wifi our data was becoming very expensive to keep adding more. The agent said the would add 1 g of data to my phone.. I was so thankful. We are still under evacuation even today.
05-14-2023 01:24 AM
Our town in Alberta has been evacuated since May 04 and we are still evacuated may 13 th.was wondering if any help from public mobility since we are staying in the country with no wifi and very expensive for the three of us. Seeing if public mobility could help in anyway .. Thank you
05-14-2023 01:20 AM
Thank you I did send a ticket. Our town has been evacuated since May 4 due to wildfires we are still under evacuation. We are staying out in the country and no wifi it is costing our family of 3 a fortune for data. Was wondering if public mobility could help.
05-14-2023 01:16 AM
Our Town in Drayton Valley, Alberta has been evacuated since May 4 th due to wildfires. Still under evacuation and still today May 13 th need to know if public mobility would help our family with phone data because we don’t have wifi out in the country where we are staying . It’s costing our 3 family members a fortune.
05-13-2023 09:25 PM
You can’t talk to an CS_Agent. You can only contact them through SIMon Chatbot or private message them.
If it is a common issue, members here can help you troubleshoot the issue. It maybe faster.
05-13-2023 05:37 PM
Hi @BethM1313 what kind of help you need? share your problem and maybe we can help
to submit ticket with PM:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
