12-06-2023
10:24 AM
12-06-2023
07:48 PM
computergeek541
I'm currently porting in my number from Zoomer to PM. So far, everything seems to be progressing as it. I still have my Zoomer SIM card in my phone (despite seeing a handful of posts that Zoomer doesn't send a confirmation text). How would I know if the porting is successful and therefore, I can exchange my Zoomer SIM card with the PM sim card?
12-06-2023 11:22 AM
unnecessary to repeat the same content given nearly an hour ago
12-06-2023 10:35 AM
Thank you both for the help!
12-06-2023 10:29 AM
@jchua Put PM SIM card in the phone call a friend does your porting number show up do all other services work text and data , be a good indication it has successfully ported over . And once your old provider SIM card no longer works . Would be safe bet all is correct
12-06-2023 10:26 AM
@jchua Does your phone still work with the Zoomer sim? Once it stops working you can take out the Zoomer sim and insert your PM sim and restart the phone and it should work.
