05-24-2023 08:25 PM
When i got to community I had no chance to login with my id only could register with email and I registered then it only offered me to get the new id, i have no way of logging in with my old id
How do I get it back?
Thanks
06-01-2023 04:54 PM
I contacted cs and was told it's something they are working on. and was told once they have a solution for this issue, they will be communicating through the community section.
So we just have to wait.
I hope not to lose the old id
05-25-2023 10:25 AM
it's crazy that they didn't send sms or emails about this switch well in advance
05-25-2023 10:17 AM
i just see this first time i don't remember getting email about this nor sms
is there any way to log into the old system?
05-24-2023 08:52 PM
Did you link your Community and your Self Serve account with the same email address?
05-24-2023 08:40 PM
Lots of people have the same issue, you can see more here: https://productioncommunity.publicmobile.ca/t5/Get-Support/Previous-Community-Profile-Not-Working/td...
At the moment there is no fix.
05-24-2023 08:28 PM
Same. Can't use old ID.
