05-21-2022
05:20 PM
05-21-2022
06:26 PM
computergeek541
I am a new customer.- 3 days ago
yesterday I became unable to recieve texts.
I get to the point where I get the link to Submit a Support Ticket
- but it doesn's accept my login credentials
- I try 611 but there is not support option and it won's accept my pin anyway.
Why do they make it impossible to get to a human??? I am screwed, I can login to Community but that is all I can acomplish, when I click the link to try to submit a ticket I get sent back to the login screen and it won't accept my credentials for that. I can log into Community, I can log into my Account details, but NOPE, not support ticket access.
Service
05-21-2022 07:50 PM
@JE1969 wrote:I will accept that as a solution, but it's far from Accetable - tech issues make it impossible to get to a human. If I had known this I would never have become a Public customer. It's irresponsible for a company to take my money but not have a way for the customer to contact tech support when the technology to get support has failed at every turn.
@JE1969 - this service model is not for everybody, but once you get a few details sorted out and know how and where to go to find information you may feel more at ease.
In the Get Help Section: https://www.publicmobile.ca/en/bc/get-help
If you type "Customer support" you will see methods to reach Public Mobile representatives for help on account issues.
Often if you ask a question here on the forum you get an answer super quick, so it is always worth a shot to try here as well. 😀
I hope you got your issue sorted out, and all is swell now!!
Welcome to Public Mobile and the Community!
05-21-2022 06:10 PM
I would recommend private message to CSA. Follow the link above or click on the envelope icon in top right of your community screen and message CS_Agent. It will be with a live human, just not over the phone but via messaging.
05-21-2022 05:39 PM
Hi @JE1969 support model here is a bot different here, all online. That's why plans are cheaper here. It not as convenient, but you won't need support a lot
05-21-2022 05:33 PM
05-21-2022 05:29 PM - edited 05-21-2022 05:29 PM
Hi @JE1969 use the message link to open ticket that way. Easier:
ke longer):
05-21-2022 05:27 PM
I have not problem getting to the link to "Submit a Ticket"
The problem comes AFTER that.
It asked me to log into my Community Account but I cannot do that , but only at this point. It says there is an error loging me in. So I click on Forgot Password but it doesn't go to reset the password it simply logs me into the basic community page and NOT into the Ticket Support system.
I can log into Community for everything BUT Support a Ticket.
I can log into my Account.
So, I am still at square 1 trying to get to a human.
05-21-2022 05:22 PM
Hi @JE1969
sorry no human here. Just joking
But support here is all online
you can open ticket with them easily at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
- you will then direct to another page to open ticket.
