05-21-2022 04:23 PM
05-21-2022 07:55 PM
@Matthewlozon60 - we are customers and member like you here on the forum. What do you mean by "have problems replying back"? Do you have a ticket in with customer support already, but cannot respond?
Check both your Inbox and Sent porting of your messages.
If you are still receiving a PUK message, try this link and see if it helps you lead you to your resolution:
05-21-2022 04:58 PM
Did you buy the phone used? If it is locked to another carrier it is a pretty painless process to get that code. You do have to contact the particular provider though
05-21-2022 04:28 PM
Hi @Matthewlozon60 what was the error message? there are different PUK for different kind of unlock
was the phone ever used on PM ? if never but was working on another provider, it is likely asking for Carrier unlock code. You have to check with the carrier where you got the phone from
