03-29-2023 09:53 AM
Will be travelling to Europe, my friend has roaming but I don't with Public Mobile. How can I go about forwarding my sms to her phone?
03-29-2023 10:09 AM
HI @MMM3
some text forwarding app you can use
https://www.familyorbit.com/blog/automatically-forward-text-messages/
but why sms forward? too much work. use Textnow for sms from friend
For 2FA, change it to other ways to receive it.
03-29-2023 10:03 AM - edited 03-29-2023 10:07 AM
One word to alter above for intent. Your to a. You could take your phone with you. But to do text forwarding will need the Public sim in - a - phone.
Adding - and the app
03-29-2023 09:59 AM
@MMM3 basically you cannot
But there are workaround.
you need to look for text forwarding app, install on your phone. Then leave your phone in Canada and have it plugged in the whole time
And best is to have someone to take care of the phone too in case you need to reboot it
