05-19-2022 06:34 PM
05-19-2022 06:38 PM
HI @Fixme12345
you can open ticket with them easily at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-19-2022 06:38 PM
@Fixme12345 Try to do this first
Change Preferred network to 3G ONLY/WCDMA ONLY
if still not work, try to reseat the SIM (power off , take sim card out and wait a minute, then put it back and power on)
05-19-2022 06:38 PM
HI @Fixme12345
05-19-2022 09:10 PM
@Fixme12345 - did you just activate a SIM card and port over from another provider?
If you have activated a new account and transferred over from another provider, note that incoming calls are usually the last to port over.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If still issues, submit a ticket with Public Mobile representatives (CSA) for help; click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
05-19-2022 11:44 PM
Did you port complete?
