12-29-2021 11:17 AM - edited 01-04-2022 04:44 AM
I am in the process of transferring my number from public mobile to fido as my services have been very bad. I was wondering how i can confirm my account number? I have given them my account number but they are unable to send the transfer due it being invalid.
12-29-2021 12:03 PM
@Huangwy3 wrote:I am in the process of transferring my number from public mobile to fido as my services have been very bad. I was wondering how i can confirm my account number? I have given them my account number but they are unable to send the transfer due it being invalid.
@Huangwy3 - Is your Public Mobile account currently in ACTIVE status?
It will need to be if you want to port the phone number over to FIDO.
If it is suspended, then change the plan to the lowest available plan of $15, then reactivate it.
Then you can port it over.
12-29-2021 11:20 AM - edited 12-29-2021 11:21 AM
Try sending the number again. Be careful there are lots of zeros in there.
12-29-2021 11:20 AM
I have multiple times
12-29-2021 11:22 AM
12-29-2021 11:23 AM
@Huangwy3 wrote:I have multiple times
Please double check against the number showing on the upper right corner in the self serve account.
12-29-2021 11:25 AM
@Huangwy3 : Another place is if you still have the welcome email from here from when you activated, the account # is embedded in the To:. You might need to open headers.
12-29-2021 11:27 AM - edited 12-29-2021 11:56 AM
The number is also embedded in the "TO" line of the initial welcome e-mail you received from Public Mobile waaaay back when you activated.
EDIT: Or, as @z10user4 just pointed out. 😉
2nd EDIT: @Huangwy3
Another thought (would seek diverse input from others), have you tried using the account number with JUST the last 7 or 8 digits, not all the 14 digits. I would surmise that other provider account number fields may not reach a 14 character limit.
Thoughts all?
12-29-2021 11:31 AM
@HALIMACS : When multiple replies are within a few minutes then sometimes just saying things differently clicks better with some readers. I don't think you needed to strikeout.
12-29-2021 11:37 AM
Oh, I did need to strikethrough @z10user4
I failed to review the posted replies. Tsk, tsk, tsk on me.... 😏
12-29-2021 11:40 AM
