03-06-2023 11:15 PM
my credit card has expired. How can I change the card details?
03-07-2023 06:52 AM
Have you ever created a My Account before? If not and you are a current customer (have been active within 90 days and have not ported out to another provider), you can submit a ticket here to: Create or forgot My Account email or password link
03-06-2023 11:31 PM - edited 03-06-2023 11:32 PM
Clear the cache and go incognito and login on a laptop or desktop.
You can also purchase a voucher and enter it by dialing 611 to activate your account.
Contact a CS_Agent to change an activate email address.
Voucher can be purchased from these locations:
Or purchase on recharge.ca
03-06-2023 11:30 PM
@SkybeatImm do you have an email yiu can login? just ask PM support to update the login to an email you have access
Please open ticket with PM support using chatbot
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
03-06-2023 11:23 PM
My account is not working. Email is not working how can I login
03-06-2023 11:22 PM
You need to login to your account and go to the Payment section and update the CC on file.
