How long does it take to receive the referal bonus?
fboybcb
Today I refered my friend to join PM and after activating his account (which works), I checked my account and it doesn't show the referal bonus. Is it instant or do I have to wait a specific time? Thanks
2 REPLIES 2
dpvu
Within the next day you should get a text saying it was successful and to log into your account to check the value.
mimmo
It is usually within a couple hours once the port is complte.  I recieved a sms and it showed up on account as well.  give it a little time and if nohing happens contact one of the mods.  are you sure the number you put in was correct?
